Old 04-24-18, 03:34 PM   #3
u3b3rg33k
Sounds like your control system is going to be worth more than the unit it is controlling. But who am I to tell you what you can spend in your project? If you wire everything correctly, it should work like a charm!
That's quite possible - I'm doing this because I want to repurpose something I own already, it's cheaper than buying a minisplit, or a traditional split system - and it won't require me to pull any permits or get licenses, and I like to tinker, so here I am.
Even it isn't the least expensive way to go about it, I'm thinking my ROI vs resistance heat should be pretty decent. I did that a bit this winter and it was not kind to my electric bill. I might even learn a bit in the process.
