200 square feet is 18.6 square meters.
To size my pump I've been following the pump sizing guide on builditsolar. He recommends .025-.075 gpm per square foot (which Heliodyne, a solar panel mfg also recommends). His testing shows siginificant gains to staying a little above .025.
Your recommendation of .6l/m/m2 max puts me at .015 gpm per square foot (unless my math is wrong which is quite possible).
What else would you recommend for piping/tubing?
