Where in SC are you?
I would not be worried about that. Does than on get any shade? I had one performing not as well and it have a big bird feather on it.
Dirt can make a difference or bird doo.
Here is mine you can easily see the three micro inverters that were replaced under warranty.
The bottom array was put in a few months later.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
