Originally Posted by Mikesolar
Why all these spacers between layers of coroplast.......when it can just be turned 90deg. With enough plates the efficiency will be high enough.
Less material between the hot/cold side will promote faster heat transfer. This allows less material to be used and a cheaper and just as useful product.
