I rekon if you want to regulate, you could drill a few holes in teh top and the bottom, problem with that is you lose allot of heat on cloudy days. best solution would be to build yourself a little microcontroller (not hard) and trip a relay everytime temp gets above your set point to turn on a cpu fan or something that blows in outside air.
