Old 09-22-16, 08:32 PM   #5
My new Elitech WJL-6000 will be here tomorrow..
I'll give it some testing, then use it on the Gree and maybe write a review..
I left the Gree connections un-insulated, so I can use the detector.
I hate using soap bubble slime. Once you get that stuff all over everything,
you have to clean it off, if you are going to install insulation that uses adhesive.
