Thread: CFL or LED
Old 10-18-12, 06:57 AM   #18
classradiance
2012
A couple of years back, I took my bed room reading lamp off-grid, using some car LEDs.
http://ecorenovator.org/forum/lighti...mps-house.html
It's still being used nightly and it works okay. But I've noticed the light is a bit on the blue side (colder?).
It's not the warm light that we get from our 120Vac LEDs used around the house.
The diameter of the wire wasn't considered. I used a small size wire, since the run was only about 12 feet.
The power loss of the wire that short is so low, it wouldn't be noticeable.
Actually, the 100 ft run from the little PV panel on the tracker is about 2 ohms!
Here's a pic of the panel used for the reading lamp. (with charge controller and small SUV battery).
But, so far both of my old car 12V PV charged batteries are working fine using a small wire gauge.
Ok .. but remember if your gauge is the wrong diameter for the Load Current then there is a risk of heating up the cable !!
So the rules are this :-
find out the power that your Light uses.
For a 10W 12V light the OHMS LAW SAYS P/V = A so 10/12 = .83A = 830mA
Nearly 1 Amp which means you can have 9 meters of .75mm diameter Twin & Earth with that light at the end of it, without a problem.
Double the Diameter of the cable then you can double the length.
This is costly over long distance so everybody ups the Voltage instead to reduce the Diameter of the cable over a long distance and hence reducing the cost of the cable.
classradiance is offline   Reply With Quote
The Following User Says Thank You to classradiance For This Useful Post:
Ryland (10-18-12)
