Old 06-29-12, 10:11 PM   #10
Ryland
I don't have a large enough basement for a heat pump water heater, they want a minimum square footage, otherwise I was thinking about going with something like the Air Tap as well, but as I see it, most of the heat in the basement is coming from the floor and walls, that is why in the summer when it's 90F upstairs the basement isn't that much warmer then when it's 50F upstairs in the winter, so in a round about way a water heater like this is a ground source heat pump and from what I read it should cost you about the same to run as the dehumidifier you currently have running if it runs as much as mine does (about half the time), so it's a win win! dry basement, hot water.
