I looked over the connection agreement. Enphase microinverter or just about any other inverter that meets UL Standard 1741 and IEEE 1547 will work
http://realgoods.com/downloads/dl/fi...english_na.pdf
https://enphase.com/sites/default/fi...Compliance.pdf
http://www.mississippipower.com/pdf/...-Agreement.pdf
Where are you getting your info?
This is very normal it our power company requires this also.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
