It is around 1987 ish These old forklifts are built very solid.
Forklift quest update. I found a local forklift mechanic he found me one that needs work. His shop is behind his house low overhead. he is doing this one like a side job so it will take a little longer to get it.
He found another forklift that had a motor he took out to rebuild for this one.
It is a HYSTER H50XL 5,000 pound lift.
He is rebuilding motor head to machine shop crank to machine shop.
The works oil pump pistons water pump bearings…
Transmission is good but he is rebuilding it while he has motor out.
Tilt cylinders getting rebuilt. Main lift cylinder getting rebuilt. It just had a brake job.
4 new tires. It runs duel fuel but I will just run propane.
Not pretty but it is in my budget and he is giving me a really good deal.
I have actually looked at this one. I wish it was a little smaller but it should do everything I need.
(My forklift lifts to much weight said no-one ever.)
This was my steel pick up last week.
Steel has doubled in price since last year. This is $2,500 worth of steel.
I have been making root rippers for subcompact backhoes.
I use ½” steel for the top plate and the blade. I will probably move to 5/8” or ¾” once I have my forklift.
Here is one made with 3/4" steel blade for a higher HP tractor.
I would like to start cutting 3/4" plate for companies. It is good money you do not have to sandblast or powder coat it.
I can not lift a full 4' x 8' plate 3/4" right now. I can cut it with my setup just not lift it.
This forklift will solve that. I can also load customer trailer of truck with the 3/4" I cut for them.
Not everyone can handle or cut that thick steel that is why there is more money in it.
