Originally Posted by r290r600
Because the unit is new I will use the R22 charge in it - I am re using the lines that I had the old R410a system on . just wanted to ensure the lines were clean before I put the new
R22 system together.. My question regarding the type of comp oil was because I have previously used "Shellite" as a flush fluid which is a fast evaporating mineral spirit on auto AC R12 systems. But the advice on the air duster/R152a looks like the way to go.
I don't recall that you actually spelled outy what it is that you are trying to do here?
You do know that when you braze HVAC copper lines, that you need to flood them with an oxygen and water free gas, right? If you don't, you will get tiny copper-oxide flakes that can plug your metering device later.
So, what are you doing with all your components?
