I am picking up a quick hitch from Harbor freight. with a 20% off coupon. It can handle up to 2,000 pounds.
This will help move the seat of the backhoe farther away from the back of my tractor. This is needed and it should make it simpler to get on and off the tractor.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
