Old 08-10-18, 05:28 AM   #7
Fordguy64
i just put in a new central air system. i put in the air handler and installed the outdoor unit ran all the electric and the line set. i then had a friend that is a HVAC tech come over and braze the line set pull vac and make sure the pressures were all good. he then registered both the indoor and out door unit for warranty purposes. his services only cost 180$. i purchased the indoor and outdoor unit from ingrams water and air for 3500~ plus a few other odd and ends i think total cost was 4200 installed. i now have a 16 seer 2 stage heat pump with a variable speed blower. also this is a 3 ton unit.
smaller units are cheaper.
The Following 2 Users Say Thank You to Fordguy64 For This Useful Post:
Daox (08-11-18), jeff5may (08-10-18)
