I do like your tip Christ, or should i call you Jesus ?.
All kidding aside that may well work for in between the two double windows mounted together.
The windows could be glued in place sealing the inner frame work between the two windows. Then just fill the big space with Co2, threw the schrader valve attached via a hose into the top of the window sill.
I don't think it would be that more difficult to do then just installing the 2nd window.
Having windows with good seals to start with would help. A older window could be touched up with a sealer and filled as you described.
Just the double double panes would be killer helpful, and no fuss.
Simply place it in the window sill on top of a Silicon or rubber compound and its good to go.
