This past weekend I put both the pulleys on the motor. I got a bolt to put in the end of the motor to hold everything on and got two thick washers to go on the end. I also continued running it in. I took it apart and the brushes still aren't fully seated, so I keep it running. Its been running since this weekend and is currently still running.
