Although it is really simple and someone said wind power can reduce home power bills by 80%, you had better use it as a backup system. Not reply on it 100%.
measure your local wind speed and blade diameter ,then use formula to calculate the outputs in watts, Test wether you build homemade wind turbines or not.
