Originally Posted by fud2468
It might be better to have another bike, or parts of one, that could use a chain drive to the generator.
Definitely. If your goal is to generate useful amounts of power, instead of just playing around like I am, then a different design is needed.
The other thing is that wear on a sidewall will shorten the tire life.
This is true! When I had the gen hub misaligned so the contact patch was too focused, it did start to show on the sidewall. I've since got it aligned better though (contact is approx 3/4 inch tall) and haven't seen any obvious wear since then.
