So, right now you're producing 50 watts an hour, or 50 Wh, or .05 kWh. How high do you think it would be reasonable to go up to with a better designed system? 100Wh? 200Wh? Would it ever be possible to generate 1 kWh per day? I'm guessing not if you ever wanted to do something else.
Kinda makes it sound like wimpy 60W solar panels actually do a descent job at collecting energy now, doesn't it?
