Old 09-20-13, 01:27 PM   #7
Interesting you should mention the freezing problem. I have a Bosch Aquastar 125B (on demand gas with a pilot light) which I am not currently using. I got it for a real deal because the previous owner had it in their cabin and their main form of heat was a fireplace. Well that fireplace sucked in so much cold air through the water heater's exhaust pipe that it froze up and cracked the heat exchanger. They had it repaired, but decided to go with an electric hot water heater after that.
