The sunroom
Below is my sunroom. Its a fairly good sized room at 32x12' and I am dearly hoping it will help heat the house a good extent this comming winter. ATM it looks as it does below. I'm looking for some tips on how to make it a more efficient heat source. The blinds are a kind of double air pocket type so they do have some insulation value and I have been putting them down at night now that its cooling off. I know it really needs more thermal mass added to it and that'll happen when my cousin moves in. However, I am wondering what other people have used to add thermal mass to their rooms? What have you found that works good for spreading heat from room to room?
