Old 02-17-14, 01:44 PM   #8
doug30293
Too Many Projects
Originally Posted by r290r600 View Post
Because the unit is new I will use the R22 charge in it - I am re using the lines that I had the old R410a system on . just wanted to ensure the lines were clean before I put the new
R22 system together.. My question regarding the type of comp oil was because I have previously used "Shellite" as a flush fluid which is a fast evaporating mineral spirit on auto AC R12 systems. But the advice on the air duster/R152a looks like the way to go.
You can also purge them with liquid propane as long as you are venting it to a safe area. We use a solvent called Citrol to clean resin from hoist chains. It is about 30% propane/isobutane - comes out of the spray can as liquid. The flashing of the propellant alone seems to boil off just about anything oil-based.
AC is correct, however, in that you still should have nitrogen in the lines when you braze them to avoid oxidation. Cap tubes and TEV's don't handle the flakes very well.
doug30293 is offline   Reply With Quote
