Old 07-27-16, 08:52 PM   #4
pinballlooking
pinballlooking's Avatar
23 SEER unit
Gree VIREO 9,000 BTU Ductless Mini Split Air Conditioner w/ Inverter, Heat Pump, Remote & 50' Lineset (115V) - Single Zone Systems - Ductless Mini Split Systems - Heating & Cooling
103 Estimated Annual Cooling Cost
27 SEER unit
GREE Terra 9,000 BTU Wall Mounted Ductless Mini Split Heat Pump System R410A 208-230 VAC - Single Zone Systems - Ductless Mini Split Systems - Heating & Cooling
88 Estimated Annual Cooling Cost
It is only $15 a year savings. But the 27SEER unit has more options like quite mode when you sleep.
More fan options 1 degree temp chang.
Submittal Data
http://resource.comfortup.com/is/con...n_subs?fmt=pdf
http://17uo7e27w1attiybs22of10v.wpen...30V1A-V3.0.pdf
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
