Originally Posted by jeff5may
I believe even if you only ran one of those turbotec units, the unit would have a greater COP versus running an air handler. By running two, you should extract even more btu's per watt of compressor power. If the turbotecs are too effective, you may not develop enough head pressure unless you choke the indoor water flow. That's what trials are for.
That's my expectation... I will be running the system with some PLCs, so I will be doing lots of trials to tune it for good efficiency.
