OK Wyrtwister
I'm confused.?? What are you trying to say? what are you comparing what to?? As well After sometime, thinking long and hard, MS HP, MS HP mmm, oh yes Mini-Split Heat Pump. When using acronyms please use them once at-least in the paragraph first.
So is running your MS-HP less expensive or with the gas you use still is a wash?? I don't understand. what your trying to say.
Thanks Randen
