jan 26 - I cut wire for the temperature sensors to the workshop and the 2 bedrooms and drilled necessary holes. The pantry and garage holes are already drilled so tonight I can solder everything up and tomorrow install everything and get it hooked up. I need to drill holes for the sensors in the trim for the closet doors. My plan on hiding the sensors is to install the wire inside the closet running it up the wall in there where it's out of sight and somewhat protected. At the top I'll drill a hole through the wall and trim and stick the sensor out to very close to the surface. A bit of white caulking will hold it in place and hide it. If I can get the caulking thin enough it shouldn't affect the reading very much.
I also went and got some pricing on the solar hotwater setup. This is seriously pissing me off at this point. Details in my solar hotwater build thread.
