Originally Posted by ecomodded
Not so much the pathetically thin plastic window insulation kits you see at the hardware store but the actual Poly sheet you find in Rolls at the hardware store.
I used 10 mil over my sliding glass doors frame
I am having problems working out quite what material you mean. Poly sheet in rolls that is 10 mil (I assume millimetres) thick is not something I am familiar with. Can you provide a link to an example of this material?
