Old 01-22-21, 11:27 AM   #7
solarhotairpanels
Originally Posted by Acuario View Post
I guess it depends partly on your feelings about large storage
As your cold water passes through the coil it will pick up heat from the tank so you won't be restricted to a short shower!
Thanks for your input Acuario
My storage tank is only 33 to 40 gallons so one shower and most of it is replaced with fresh city water. Doesn't sit around in that tank any longer then a regular electric hot water heater would.
My wife just used the hot water at the kitchen sink for awhile on some dishes then went up and took a shower. That's it.. it's history / gonzo. :-}
Sun is shining great so my solar pump is kicking in now re heating the storage tank.
So far so good.. everything is working as planned now.
Pat from Warwick, RI
Please Note:
Comments and/or suggestions I make here at the forums on 'your' projects as well as my own have all been carefully and scientifically calculated by 'the seat of my pants'
