Old 07-09-14, 12:37 PM   #42
natethebrown
I've also had zero issues with the HydroRight.
If you're having issues with not enough flush power, I'd try to raise the water level in the tank as high as possible (more pressure head). As for the sealing, I'm not sure. Mine have been leak free since install. Just make sure your zip ties are tight and push it down.
That is part of the problem, I cannot raise the water level in the tank any higher because the water level is already at the top of the tank fill tube. I will give it one more go at adjusting and checking everything out to try to stop the leak, and after that I am going to give up. I really don't have the time to keep messing with it, right now.
