Originally Posted by Mikesolar
Always plumb them in parallel. I assume they are to be complete heat pumps and you are doing all this on the water side because if it was on the refrigerant side, it is a whole other world.....
Yes talking about the water side(ground loop and output to buffer tank).
Going to make them stand alone heat pumps selected my a master controller switching in the appropriate sized pumps as required.
Not even had time to take apart either of the 2 units i have stored away for this.
At least the floor screed is down and drying so when i do get a heat pump together i'll have something to heat with it.
Lots of snow outside so slow progress right now.
