Old 07-16-20, 10:00 PM   #10
nokiasixteth
Yes, ventilation will help carry away waste heat. Not a huge amount, but yes it will be helpful.
The most effective thing you can do to increase cooling is to mist the outdoor unit heat exchanger. Any way you slice it, the mist helps. I used to be a skeptic, but not anymore. It seems the dumber and lower seer rating your system is, the more it helps. The variable speed inverter units get a boost, but not as much as an older single speed, cap tube metered unit.
I haven't hooked a mister up yet this year. Where I am (Kentucky USA by fort Knox), the savings don't really stack up until the daily highs rise above body temperature. What I have is a kiddie pool reservoir in the shade, that feeds from the air conditioner drain. If you have soft tap water (I don't, Kentucky tap water is full of lime), you can use that. I have a little submersible fountain pump hooked up to some fine spray nozzles. The pump runs off a wind vane switch mounted on the discharge from the outdoor unit. When the unit turns on its fan, the pump starts misting.
You can read this and read that about it, or just do it and see if it works for you. I noticed the misting in action, and experimented with it, a dozen or more years ago, with window shakers. The outdoor fan on about every one has a ring around it that slings condensate on the outdoor HX. I noticed that the hotter it gets outside, the better the water slinger works to drive down supply air temperature indoors. I saw that in the absence of the drain water, the compressor power draw was 20 to 30 percent higher than with the drain water. Inside, the discharge air really depended on the outside temperature. On a hot day, the difference between water and no water cooling was 10 to 15 degF.
The house I'm in now has a 13 seer trane heat pump in it, single speed with txv metering. It does a pretty good job until it gets hot and muggy outside. We're just getting into that time of year now, so I might be setting up the misting rig soon. I'll probably need to find a reservoir, as the one I was using is now a big dog water bowl/bath.
Keeping the outdoor unit in the shade helps, too.
I have a rig and 100ft of pipe. I have been told here geothermal is 250ft per ton. I wonder if i could dig 3 holes each 100 ft deep. Put some hdpe pipe in each hole with a controller that sensed when water changed temps it would flow after exchanging heat. A radiator big enough for adequate air flow intake for the mini split . Basically the air would be pre cooled before going into the mini split . Being i dont have the tools or anything to make a full blown geothermal air conditioner. Wonder if it would be worth the investment or just a waist of time.
nokiasixteth is offline   Reply With Quote
