Old 07-25-16, 02:12 PM   #7
Default Kinda working..
I'm not so sure.. I found a user that's had a lot of problems with this model..
Sante Fe Classic Quality Issues
He's included five links to YouTube videos in his posts..
Mine seems to be working poorly. Only getting about a quart during a 1 hour run..
Temp 70F with RH between 60 & 70 percent.
I'm wondering if a Superheat test could tell me anything..
First, I'll have to find out what the 'standard' Superheat temperature is for this model. At 70F & 70%RH..
After a 1/2 hour warm up, I did a little testing of the input air vs the output air.
Input air was 62%RH @ 73deg
Output was 38%RH @ 82deg
A change of 24%RH & 9 deg.
