Old 09-10-15, 08:32 PM   #11
Originally Posted by Leafgreen View Post
Cooking with wood is not "carbon neutral". You are referring to carbon emissions into the air. Yeah, wood contains carbon. But if you throw a log into a forest, it won't end up as smoke in the air, unless it gets burned.
This sounds too much like the ethanol fuel debate... don't starve the world by using up all the corn for fuel... distilling alcohol is immoral... your car won't run on it... methanol won't work either... freedom of choice is bad... blaggety blaargh.
The real question is: wouldn't my turds replace the scorched wood after I digested that massive, juicy steak? Or is that just another form of restricted waste to sequester?
