I finished the putting together the open source EVSE. It is now helping my Chevy Volt get charged up.
One good side benefit is it uses less than 1 watt in standby. This should help in my quest to lower my standby load.
It was a lot of drilling and getting everything to fit in the box. The 10 gauge wire is very stiff to work with. I am happy with the end results.
For the 8 gauge wire I used left over pieces from my solar project.
The second picture shows it actually charging my Volt.
I based my component layout off this build.
http://code.google.com/p/open-evse/wiki/30A_OpenEVSE
A lot of the parts I ordered were based off this build.
http://code.google.com/p/open-evse/wiki/EVSE_by_4Dolio
