Old 08-25-18, 11:28 AM   #4
Zwerius
Zwerius's Avatar
6" is more or less "old school" overhere in the Netherlands. 4" (or even less!!) is favourable, especially when you are using a heatpump. Or if you are planning to use one in the future.
More tubelength (so closer tubing), means lower watertemperature for the same amount of heat.
And lower watertemperature means a more efficient heatpump.
The difference in e-consumption is about 2,5% per °C.
So if you ar planning a hydronic heating right now, please do it right the first time.....
Zwerius is offline   Reply With Quote
