Originally Posted by brogsie
Didn't realize it got that cold last night. The Fujitsu kept up OK. Are the Sanyos just that much older they don't have the technology for temps near zero?
He is afraid of damaging the units if the power use goes up too high and he doesn't run them if they will be defrosting. I'm sure they would probably be able to keep up and be cheaper to run than oil and space heaters if he let them do the work. His units aren't the most efficient but they should be better than his backup heat.
