re:
Safe AS much rain water as you can
Read that due to water rights laws (first in time, etc) it is illegal in CO to even have a rain barrel without having state granted water 'rights'. You are supposed to let it runoff so the state can allocate it ?
Obviously to the biggest political donors ?
Anyone conversant on that matter ?
As far as fie safe, CA has some pretty strict codes. Son built a house near Nevada City, stucco or brick or stone a must, no overhang, no wooden decks, etc. Might pay to pullup the CA fire zone codes and take a look.
BTW, at 8800 ft, your solar arrays, if you use triple junction cells, will give you abut 10% higher output than at sea level! Put an array on Haleakala, HI 15 or so years ago, have the wavelength insolation numbers somewhere if you are interested. Not as much advantage from single junction cell arrays.
