You said:
"For instance, it seems to me that a ceiling-emitter system would face a higher temperature due to stratification, which would result in the need for greater delta-T to drive heat into the room. So this might be seen as a less desirable configuration, given the design goal."
Therefore I thought that your question had something to do with some previous topic. Perhaps you were just using it as a way to illustrate your question and he responded to that alone.
