Old 08-12-20, 01:35 PM   #14
pinballlooking
pinballlooking's Avatar
Originally Posted by where2 View Post
Your comment isn't as odd as it may seem on the surface. I spend my weeks sitting behind a PC pushing a mouse creating digital design projects, but I find doing tangible hands-on projects on the weekend much more fulfilling. My most recent weekend accomplishments have been a collection of 2-cycle engines. Whether it's fixing the 20" chainsaw I picked up for $10, or the 2-cycle string trimmer my neighbor tossed on the swale for the trash collectors... Rebuilding a mini-carburetor and replacing a few fuel lines to get a small engine running is a skill that some will never master. Meanwhile, I have two running string trimmers and two chainsaws for every property we own... Then there were the two generators my neighbors tossed out for the scrap guys. One had a blown generator head. I took the Robin (Subaru) engine from one, and installed the 5KW generator head from the other. Then, I dialed in the frequency to 60Hz using my Kill-A-Watt... I also managed to resurrect the Briggs & Stratton engine from the donor generator, which I will likely gift to a friend to repair his mom's generator.
Next weekend project will be pulling the hydraulic leveling jacks off the RV frame to have the seals replaced.
Cool projects. I love saving stuff from the scrap yard. Those Subaru motors are good motors.
You could probably sell the copper from the bad head.
My son is starting collage and the tractor accessory's are slowing a little and my other work is really picking up. I guess it is all working out.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
