I plugged in my kill a watt to the fridge last night to start logging pre-mod energy usage. In the 10.5 hours since plugging it in (overnight), it used .5 kWh. So, the estimated daily usage at this point is ~1.14 kWh. However, that really isn't a good number since I don't think we opened it many times after adding the meter. Last time I did this I saw pretty large swings in energy usage. However, after 925 hours of logging (38.5 days), I ended up with 1.37 kWh/day. We'll see how things compare after a week or two.
