Thread
Cutting Rigid Foam Board the Easy Way
01-05-14, 08:18 AM
5
Mikesolar
Originally Posted by
this works for me.
$0.75 Handheld Hot-Wire Foam Cutter - YouTube
To cut larger sections or swaths, I rig up a stationary vertical wire section to some jumper cables on the side of a bench.
Cutting foam with heat produces pretty nasty gasses so I think the blade idea is way better.
Mikesolar
View Public Profile
Send a private message to Mikesolar
Find More Posts by Mikesolar
