sump pump B/U
I suppose an overall assessment would be my plan. Do I want other things to work besides the pump. Maybe a generator would be a good overall choice. One has to think how often it happens and how long it stays off.
My basement has floor drains in case there is a leak but does not allow ground water in either because of the drainage system I installed when I built it.
Because we are rural and the power can be off for extended amounts of time I installed a 50KW 3ph Kohler on propane.
