I think you will still need that big honking machine. I find it hard to believe that you can dense pack anything with one of those anemic Home Cheapo machines. Get a tester and make sure it can blow 2.8 or get a different machine. That stuff WILL settle and then you're worse off than if you just putt FG batts up.
My project:
