Thread: CFL or LED
Old 10-13-12, 05:47 PM   #7
Since the wattage is so low, I have not tried to get an accurate measurement..
I just used my 'new' meter (not sure how good it works at low power) and my 100W(eq) CFL used 25W.
I've replaced two of those 100W(eq) CFLs with 60W(eq) LEDs that use 12W. (2 table lamps).
In my work areas, I've replaced 75W & 100W CFLs with 40W(eq) LEDs using 8.6W. (little desk lamps). Worked out pretty well.
There are five of those 40W(eq) LEDs hanging above the dinning table.
So, that fixture is burning up 8.6 x 5 = 43 watts.
That 43 watts of LED above the table is plenty bight.
It compares pretty well to using five incandescent 40w blubs (200W).
Before we installed the five 40W(eq) LEDs in that fixture,
we had 65W(eq) 11W CFL spots installed. They were way too weak..
I got those 65W(eq) CFL spots very cheap (on sale at HD) and they stink.
Much weaker than expected and very sensitive to cold (or even cool) temps.
Those 40w(eq) decorator LEDs in the bedroom and bath are bright!
I have to use the dimmer in the bedroom. It's too much in morning..
The bath doesn't have a dimmer, so when it comes on, be ready!!
When taking a shower, I've noticed a lot better lighting in the tub area now..
Those LEDs are the best lighting we've had in the bathroom..
(But now, I'm thinking about trying another dimmer in there )..
