Old 09-01-16, 12:26 PM   #9
Originally Posted by pinballlooking View Post
It looks in good shape. How does the indoor unit look?
Mini split with Wi-Fi standard is very cool.
The front face cover looks nice, but sadly, I just opened box and checked for breakage. Didn't remove it from the box..
I wanted to bring it into the living room. But that area is off-limits until Sunday.
The remote has some good stuff on it. Programmable timer looks really neat.
IIRC, you can program the temperature for sleeping, and set what temp you want, eight times, for all eight hours of sleep..
I read about the app in the manual, and it requires you to go into your
wifi setup and select the Gree's wifi port. The only thing I saw 'extra'
was a eco performance or power saver mode.
It works by not just looking at the indoor temp, but also the outdoor temp..
Maybe when outdoors is warming up, it doesn't try to heat indoors as much?
That's something I would like to try..
I didn't read everything. I'm sure the app has changed during the last year..
I think the name of the app is different now. I have not downloaded it yet.
