Originally Posted by pinballlooking
I really like micro inverters one reason is one thing cannot take the whole array off line. Sure you have a inverter warranty but it does not cover lost power being made we make from $200-$100 a month if you are down for a few month that adds up fast. (just under $2,000 a year)
If a microinverter fails I have a spare on hand I replace it send bad one off for warranty no big deal. (I have had not failures yet knock on wood)
Another reason it you can check each panel/microinverter at a glance and if one is having issue it is very simple to see. It is very easy for a home owner trouble shoot the issue. You don’t have to wonder if it is working or call someone in to look at in for $100 and hour plus travel.
This view is priceless for trouble shooting.
You can also graph a single Microinverter.
Power produced
DC voltage
Dc current
AC voltage
AC frequency
Temperature
That is somethin else to think about. Replacement cost of inverter. Seen in another post you really don't get much clipping with your inverters though
