I agree with Bernie. As currently built, only a small fraction (10%?) of the water will flow over the copper coil. But a simple solution exists. Just block off the interior central hole with a PVC plug made of tubing and end caps. This will force the water to flow over the coil and will result in much better heat transfer.
I am concerned about the material used to plug the holes where the copper tubing comes out. Time will tell.
Great start however!
Steve
