The problem that I have with the PAR30 bulb is that it's a spot light/flood light bulb that has an enclosed reflector around it that I assume prevents them from making it an instant on bulb due to the heat that would build up and wear it out faster.
Otherwise I really like CFL's in bath rooms as the light level matches what your eyes can handle.
For other flood light bulb needs I would go with LED's as you can now get ones that should replace a 60-75 watt bulb.
