Mine has an Activation Flow Rate: 0.40 GPM. When I was searching for a unit I looked for a low Activation Flow Rate.
You can make your sinks flow a higher rate.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
