The loops are charged with water and antifreeze. They are holding pressure.
I have probably 98% air out I just have the manifold looped back into its self at this point.
I have about 20’ of trench open to the house that I can now start filling back in.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
