Memphis,
Does the inverter you are using turn off AC production if you have a grid power failure? If it does not, then the electric company will "find" you. Then they can fine you . . .
If I recall, your total power from your PV panels is about 800 watts. Running this over the day MORE than pays for your well water heat pump.
Glad your meter works - you are just one more in the group that has success with existing meters.
Steve
